MechMachineMan
Is there a good reason you need to use the specific WeldmentComponentDefinition instead of the generic ComponentDefinition?
From my messing around with this, it appears to work just fine.... I'm assuming refdoc probably isn't actually a weldmentcomponentdefinition like you expect it to be.
Sub Main()
	Dim oCD As ComponentDefinition
	For Each oSubDoc in ThisDoc.Document.AllReferencedDocuments
		If oSubDoc.DocumentType = kAssemblyDocumentObject 'AssemblyDocument
			If oSubDoc.ComponentDefinition.Type = ObjectTypeEnum.kWeldmentComponentDefinitionObject
				Dim oWCD As WeldmentComponentDefinition = oSubDoc.ComponentDefinition
				oCD = oWCD
				MsgBox(oWCD.Document.FullFileName)
				Goto Continue1
			Else
				Dim oACD As AssemblyComponentDefinition = oSubDoc.ComponentDefinition
				oCD = oACD
			End If
		Else 'Part Doc
			If oSubDoc.ComponentDefinition.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject
				Dim oSCD As SheetMetalComponentDefinition = oSubDoc.ComponentDefinition
				oCD = oSCD
			Else
				Dim oPCD As PartComponentDefinition = oSubDoc.ComponentDefinition
				oCD = oPCD
			End If
		End If
	Next
Continue1:
	MsgBox(oCD.Document.FullFileName)
End Sub
'kVirtualComponentDefinitionObject - 100675072
'kWeldmentComponentDefinitionObject - 100673280
'kAssemblyComponentDefinitionObject - 100663808
'kPartComponentDefinitionObject - 83886592
'kSheetMetalComponentDefinitionObject - 150995200
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
