07-24-2017
01:34 PM
- Mute
- Permalink
- Report
07-24-2017
01:34 PM
If I understand your request correctly.. there is no easy way of getting that. If you have reused frame generator members then they are one item on disk and then only show up once in parts list and BOM.
However, by default Inventor will create a unique file for each curve you selected in your skeleton.
You want inventor to identify and cumulate identical items but that won't be possible without some sort of geometry overlapping and comparing and even then what happens if you add a hole to one of the members, do you expect all of them to have this hole or just that member?
Curtis had a nice explanation on how to do this, but it's a bit of work. Here it is.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
blog.ads-sol.com
