- Mute
- Permalink
- Report
Parsing the Recent Changes Enum
I've tried a couple different things but I cant seem to get it to click.
What I want to do is use the RecentChanges property of a document to control when I want a global event trigger to proceed.
I understand that the RecentChanges returns an enum that is an addition of the children that are flagged, but what I can't currently do is establish out of that value which of the children are flagged on without writing a large tree structure.
From the browsing I have done on the msdn site, it looks like enums are set-up to get them to do this for you, in the form of an array, but I can't seem to get it working.
ie; if oDoc.RecentChanges returns a value of 145, I want to find the function/method that spits an array out containing only (128, 16, 1) so then I can do an "If array contains 128 OR ARRAY Contains 32"
Here is the mishmash of things I have tried so far:
Dim oDoc As Document = ThisDoc.Document
''Below fails because it says RecentChanges is not a collection 'For Each i In oDoc.RecentChanges ' MsgBox(i) 'Next
''Below simply returns the value of the combined enums; in my test case, this was 145 (which is 128, 16, 1) MsgBox(CStr(oDoc.RecentChanges))
'Below says that commandtypesenums is not part of ienumerable For Each i In [Enum].Parse(GetType(CommandTypesEnum), oDoc.RecentChanges)
MsgBox(i)
Next
'Below just lists all possible enums in CommandTypesEnum For Each i In [Enum].GetValues(GetType(CommandTypesEnum)) MsgBox(i) Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
