07-20-2017
12:11 PM
- Mute
- Permalink
- Report
07-20-2017
12:11 PM
With how it was written, I definitely had difficulty in understanding why you would go through the trouble of making the whole param array only to check it against itself and apparently establish a type based off of that.
The confusing part is why you didn't just write a simple case/if structure to check the existence of parameters in a part and make a type based off of that.
ie;
Sub Main()
If ParamsExist(oDoc, "G_L", "A_F") = True Then
Type = "Plastic"
Else if ParamsExist(oDoc, "b", "t", "k") = True Then
Type = some custom type
End if
End SUb
Function ParamsExist(oDoc, ByVal ParamArray paramstocheck As String()) As Boolean
For each oParam in paramstocheck
Try
oDoc.Parameters(oParam)
Catch
'Accessing prop failed; it doesn't exist
Return False
Exit Sub
End Try
Next
Return True
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
