07-05-2017
01:42 PM
- Mute
- Permalink
- Report
07-05-2017
01:42 PM
If you are using this with iTriggers it is HIGHLY, HIGHLY recommended you go back through the code and replace
ThisApplication.ActiveDocument
with
ThisDoc.Document
Using the latter ensures that the rule grabs the document that the rule was triggered in, not the document that is at the forefront of the screen.
Also, add this at the very start:
If ThisDoc.Document.DocumentType <> kAssemblyDocumentObject Then
MsgBox("Rule only for assemblies; was triggered to run for: " & vblf & vblf & _
ThisDoc.Document.FullFileName & vblf & vblf & _
"... Aborting Rule!")
Exit Sub
End if
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
