'TURNING COLLAR PARTS PHANTOM WHEN BELLOWS TYPE = FORMED
If O_COLLAR_SEWING_TYPE= "FORMED" Then
ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("Ilogic").Activate
iLogicVb.UpdateWhenDone=True
' set a reference to the assembly component definintion
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
	If Component.IsActive("ROUND_FLANGE1")=True Then
	Dim oOccurrence As ComponentOccurrence
	For Each oOccurrence In oAsmCompDef.Occurrences
		If oOccurrence.Name.Contains("ROUND_FLANGE1") = True Then
		oOccurrence.Definition.BOMStructure = 51971 'Phantom
		End If
		Next
	End If
	If Component.IsActive("ROUND_FLANGE2")=True Then
		If oOccurrence.Name.Contains("ROUND_FLANGE2") = True Then
		End If
		Next
	End If
	If Component.IsActive("ROUND_FLANGE3")=True Then
		If oOccurrence.Name.Contains("ROUND_FLANGE3") = True Then
		End If
		Next
	End If
	If Component.IsActive("ROUND_FLANGE4")=True Then
		If oOccurrence.Name.Contains("ROUND_FLANGE4") = True Then
		End If
		Next
	End If
	If Component.IsActive("ROUND_COLLAR1")=True Then
		If oOccurrence.Name.Contains("ROUND_COLLAR1") = True Then
		End If
		Next
	End If
	If Component.IsActive("ROUND_COLLAR2")=True Then
		If oOccurrence.Name.Contains("ROUND_COLLAR2") = True Then
		End If
		Next
	End If
	If Component.IsActive("EXPANDED_COLLAR1")=True Then
		If oOccurrence.Name.Contains("EXPANDED_COLLAR1") = True Then
		End If
		Next
	End If
	If Component.IsActive("EXPANDED_COLLAR2")=True Then
		If oOccurrence.Name.Contains("EXPANDED_COLLAR2") = True Then
		End If
		Next
	End If
	If Component.IsActive("CONE_END1")=True Then
		If oOccurrence.Name.Contains("CONE_END1") = True Then
		End If
		Next
	End If
	If Component.IsActive("CONE_END2")=True Then
		If oOccurrence.Name.Contains("CONE_END2") = True Then
		End If
		Next
	End If
End If
If O_COLLAR_SEWING_TYPE= "SEWN" Then
		oOccurrence.Definition.BOMStructure = 51970 'NORMAL
		End If
	Next
	End If
		End If
	Next
	End If
		End If
	Next
	End If
		End If
	Next
	End If
		End If
	Next
	End If
		End If
	Next
	End If
		End If
	Next
	End If
		End If
	Next
	End If
		End If
	Next
	End If
		End If
	Next
	End If
End If
'VARIABLE SWITCH COLLAR1
If (24>=O_COLLAR1 And O_COLLAR1>12) Then
	VARIABLE_1 = O_COLLAR1/2
	Else
	VARIABLE_1=0
End If
If (36>=O_COLLAR1 And O_COLLAR1>24) Then
	VARIABLE_3 = O_COLLAR1/3
	Else
	VARIABLE_3 = 0
End If
If (48>=O_COLLAR1 And O_COLLAR1>36) Then
	VARIABLE_5 = O_COLLAR1/4
	Else
	VARIABLE_5 = 0
End If
If (60>=O_COLLAR1 And O_COLLAR1>48) Then
	VARIABLE_7 = O_COLLAR1/5
	Else
	VARIABLE_7= 0
End If
'VARIABLE SWITCH COLLAR2
If (24>=O_COLLAR2 And O_COLLAR2>12) Then
	VARIABLE_2 = O_COLLAR2/2
	Else
	VARIABLE_2=0
End If
If (36>=O_COLLAR2 And O_COLLAR2>24) Then
	VARIABLE_4 = O_COLLAR2/3
	Else
	VARIABLE_4 = 0
End If
If (48>=O_COLLAR2 And O_COLLAR2>36) Then
	VARIABLE_6 = O_COLLAR2/4
	Else
	VARIABLE_6 = 0
End If
If (60>=O_COLLAR2 And O_COLLAR2>48) Then
	VARIABLE_8 = O_COLLAR2/5
	Else
	VARIABLE_8 = 0
End If
'CLAMP SELECTION SEWN O_COLLAR1 CODE
		Component.IsActive("11000063") = False
		Component.IsActive("11000064") = False
		Component.IsActive("11000065") = False
		Component.IsActive("11000066") = False
		Component.IsActive("11000067") = False
		Component.IsActive("11000068") = False
		Component.IsActive("11000069") = False
		Component.IsActive("11000070") = False
		Component.IsActive("11000071") = False
		Component.IsActive("11000138") = False
If O_CLAMP Then
	If (O_COLLAR1<= 1.25) And O_COLLAR1> 0 Then'Or (O_COLLAR2<=1.25) Then
			Component.IsActive("11000063") = True
			'quantity = ThisBOM.CalculateQuantity("Model Data", "11000063")
		ElseIf (1.75>=O_COLLAR1 And O_COLLAR1>1.25) Then'Or (1.75>=O_COLLAR2 And O_COLLAR2>1.25) Then
			Component.IsActive("11000064") = True
			'quantity = ThisBOM.CalculateQuantity("Model Data", "11000064")
		ElseIf (2.25>=O_COLLAR1 And O_COLLAR1>1.75)Then' Or (2.25>=O_COLLAR2 And O_COLLAR2>1.75) Then
			Component.IsActive("11000065") = True
			'quantity = ThisBOM.CalculateQuantity("Model Data", "11000065")
		ElseIf (2.75>=O_COLLAR1 And O_COLLAR1>2.25)Then' Or (2.75>=O_COLLAR2 And O_COLLAR2>2.25) Then
			Component.IsActive("11000066") = True
			'quantity = ThisBOM.CalculateQuantity("Model Data", "11000066")
		ElseIf (4>=O_COLLAR1 And O_COLLAR1>2.75)Then' Or (4>=O_COLLAR2 And O_COLLAR2>2.75) Then
			Component.IsActive("11000067") = True
			'quantity = ThisBOM.CalculateQuantity("Model Data", "11000067")
		ElseIf (6>=O_COLLAR1 And O_COLLAR1>4) Then'Or (6>=O_COLLAR2 And O_COLLAR2>4) Then
			Component.IsActive("11000068") = True
			'quantity = ThisBOM.CalculateQuantity("Model Data", "11000068")
		ElseIf (7>=O_COLLAR1 And O_COLLAR1>6) Then'Or (7>=O_COLLAR2 And O_COLLAR2>6) Then
			Component.IsActive("11000069") = True
			'quantity = ThisBOM.CalculateQuantity("Model Data", "11000069")
		ElseIf (8.25>=O_COLLAR1 And O_COLLAR1>7) Then'Or (8.25>=O_COLLAR2 And O_COLLAR2>7) Then
			Component.IsActive("11000070") = True
			'quantity = ThisBOM.CalculateQuantity("Model Data", "11000070")
		ElseIf (10>=O_COLLAR1 And O_COLLAR1>8.25)Then' Or (10>=O_COLLAR2 And O_COLLAR2>8.25) Then
			Component.IsActive("11000138") = True
			'quantity = ThisBOM.CalculateQuantity("Model Data", "11000138")
		ElseIf (12>=O_COLLAR1 And O_COLLAR1>10)Then' Or (12>=O_COLLAR2 And O_COLLAR2>10) Then
			Component.IsActive("11000071") = True
			'quantity = ThisBOM.CalculateQuantity("Model Data", "11000071")
	'O_CLAMP >12ID<=24
		ElseIf (24>=O_COLLAR1 And O_COLLAR1>12) Then'Or (24>=O_COLLAR2 And O_COLLAR2>12) Then
				If (7>=VARIABLE_1 And VARIABLE_1>6)Then' Or (7>=VARIABLE_2 And VARIABLE_2>6) Then
					'ThisBOM.OverrideQuantity("Model Data","11000069", 2)
				ElseIf (8.25>=VARIABLE_1 And VARIABLE_1>7) Then'Or (8.25>=VARIABLE_2 And VARIABLE_2>7) Then
				'ThisBOM.OverrideQuantity("Model Data","11000070",2)
				ElseIf (10>=VARIABLE_1 And VARIABLE_1>8.25)Then' Or (10>=VARIABLE_2 And VARIABLE_2>8.25) Then
					'ThisBOM.OverrideQuantity("Model Data","11000138", 2)
				ElseIf (12>=VARIABLE_1 And VARIABLE_1>10) Then'Or (12>=VARIABLE_2 And VARIABLE_2>10) Then
				'ThisBOM.OverrideQuantity("Model Data","11000071", 2)
				End If
	'Clamp 24>ID<=36
		ElseIf (36>=O_COLLAR1 And O_COLLAR1>24) Then'Or (36>=O_COLLAR2 And O_COLLAR2>24) Then
				If (8.25>=VARIABLE_3 And VARIABLE_3>7) Then'Or (8.25>=VARIABLE_4 And VARIABLE_4>7) Then
				'ThisBOM.OverrideQuantity("Model Data","11000070", 3)
				ElseIf (10>=VARIABLE_3 And VARIABLE_3>8.25)Then' Or (10>=VARIABLE_4 And VARIABLE_4>8.25) Then
				'ThisBOM.OverrideQuantity("Model Data","11000138", 3)
				ElseIf (12>=VARIABLE_3 And VARIABLE_3>10)Then' Or (12>=VARIABLE_4 And VARIABLE_4>10) Then
				'ThisBOM.OverrideQuantity("Model Data","11000071", 3)
				End If
	'Clamp 36>ID<=48
		ElseIf (48>=O_COLLAR1 And O_COLLAR1>36) Then'Or (48>=O_COLLAR2 And O_COLLAR2>36) Then
				If (10>=VARIABLE_5 And VARIABLE_5>8.25) Then'Or (10>=VARIABLE_6 And VARIABLE_6>8.25) Then
				'ThisBOM.OverrideQuantity("Model Data","11000138", 4)
				ElseIf (12>=VARIABLE_5 And VARIABLE_5>10) Then'Or (12>=VARIABLE_6 And VARIABLE_6>10) Then
				'ThisBOM.OverrideQuantity("Model Data","11000071", 4)
				End If
	'Clamp 48>ID<=60
		ElseIf (60>=O_COLLAR1 And O_COLLAR1>48) Then'Or (60>=O_COLLAR2 And O_COLLAR2>48) Then
			If (10>=VARIABLE_7 And VARIABLE_7>8.25) Then'Or (10>=VARIABLE_8 And VARIABLE_8>8.25) Then
			'ThisBOM.OverrideQuantity("Model Data","11000138", 5)
			ElseIf (12>=VARIABLE_7 And VARIABLE_7>10) Then'Or (12>=VARIABLE_8 And VARIABLE_8>10) Then
			'ThisBOM.OverrideQuantity("Model Data","11000071", 5)
			End If
	End If
End If
'COLLAR 2
If O_CLAMP Then
	If  (O_COLLAR2<=1.25) And O_COLLAR2> 0 Then
		ElseIf  (1.75>=O_COLLAR2 And O_COLLAR2>1.25) Then
		ElseIf (2.25>=O_COLLAR2 And O_COLLAR2>1.75) Then
		ElseIf  (2.75>=O_COLLAR2 And O_COLLAR2>2.25) Then
		ElseIf  (4>=O_COLLAR2 And O_COLLAR2>2.75) Then
		ElseIf  (6>=O_COLLAR2 And O_COLLAR2>4) Then
		ElseIf  (7>=O_COLLAR2 And O_COLLAR2>6) Then
		ElseIf  (8.25>=O_COLLAR2 And O_COLLAR2>7) Then
		ElseIf  (10>=O_COLLAR2 And O_COLLAR2>8.25) Then
		ElseIf  (12>=O_COLLAR2 And O_COLLAR2>10) Then
'O_CLAMP >12ID<=24
		ElseIf  (24>=O_COLLAR2 And O_COLLAR2>12) Then
				If  (7>=VARIABLE_2 And VARIABLE_2>6) Then
					'ThisBOM.OverrideQuantity("Model Data",11000069, 2)
				ElseIf  (8.25>=VARIABLE_2 And VARIABLE_2>7) Then
					'ThisBOM.OverrideQuantity("Model Data",11000070,2)
				ElseIf (10>=VARIABLE_2 And VARIABLE_2>8.25) Then
				ElseIf  (12>=VARIABLE_2 And VARIABLE_2>10) Then
					'ThisBOM.OverrideQuantity("Model Data","11000071",2)
				End If
		'Clamp 24>ID<=36
		ElseIf  (36>=O_COLLAR2 And O_COLLAR2>24) Then
				If  (8.25>=VARIABLE_4 And VARIABLE_4>7) Then
				ElseIf  (10>=VARIABLE_4 And VARIABLE_4>8.25) Then
				ElseIf  (12>=VARIABLE_4 And VARIABLE_4>10) Then
				End If
		'Clamp 36>ID<=48
		ElseIf  (48>=O_COLLAR2 And O_COLLAR2>36) Then
				If  (10>=VARIABLE_6 And VARIABLE_6>8.25) Then
				ElseIf  (12>=VARIABLE_6 And VARIABLE_6>10) Then
				End If
	'Clamp 48>ID<=60
		ElseIf (60>=O_COLLAR2 And O_COLLAR2>48)  Then
			If  (10>=VARIABLE_8 And VARIABLE_8>8.25) Then
			ElseIf (12>=VARIABLE_8 And VARIABLE_8>10)  Then
			End If
	End If
End If
'O_CLAMP >12ID<=24
If O_CLAMP Then
			'Component.IsActive("11000063") = True
			'Component.IsActive("11000064") = True
			'Component.IsActive("11000065") = True
			'Component.IsActive("11000066") = True
			'Component.IsActive("11000067") = True
			'Component.IsActive("11000068") = True
			'Component.IsActive("11000069") = True
			'Component.IsActive("11000070") = True
			'Component.IsActive("11000138") = True
			'Component.IsActive("11000071") = True
				End If
		'Clamp 24>ID<=36
				End If
		'Clamp 36>ID<=48
				End If
	'Clamp 48>ID<=60
			End If
	End If
End If
'COLLAR 2
If O_CLAMP Then
'O_CLAMP >12ID<=24
	If  (O_COLLAR2<=1.25)And O_COLLAR2> 0 Then
				End If
		'Clamp 24>ID<=36
				End If
		'Clamp 36>ID<=48
				End If
	'Clamp 48>ID<=60
			End If
	End If
End If
