456 Views, 2 Replies
06-05-2017
10:24 AM
- Mute
- Permalink
- Report
06-05-2017
10:24 AM
Exporting files with revision level in the filename
I'm trying to see if there is a way to use Task Scheduler or something along those lines to be able to export Inventor .IDW files to a .dxf with the Inventor revision level in the name. For example export Inventor_part.idw to Inventor_part_REVA.dxf. I'm currently running Autodesk Inventor Professional 2015. If this isn't directly possible to do in Task Scheduler, can this be done through the .ini file for the file export, or a .xml file for the customization feature? I would appreciate any help I can get.
