Look i,m looking for a specific thing i wan't to create an event this event enabling me to select a face and create a sketch on this plane and constrain this sketch to two adjacent lines on this sketch the event will loop inside the face until find the outer edges (interaction events Object i had searched on inventor API help and i found no effective clue  you can help me or find somebody he could) and then i can constrain the sketch it's not a problem to a form to change setting all what i want a code the will help me to do this function all other things is not a problem >> please for the sake of saving your precious time and also mine help me or find out some body that he could and if creating this event so complicated or not possible please directly tell me
there is a sample of the code that i was trying to use attached below
i had build that and i hope some body give me any clue
