05-30-2017
03:43 PM
- Mute
- Permalink
- Report
05-30-2017
03:43 PM
So let's start with the basics then.
1) What is the input that will be required from your user BEFORE running the rule?
- Just as the hole command must be used on a point, the slot command would likely need to be used on a sketch feature of some kind. Especially for creating a basic version, this is a good start.
2) What parameters do you want the user to be able to control about the slot that aren't available in the Extrusion command?
3) How much does this actually benefit your workflow and speed things up over the current workflow:
1. Create sketch
2. Create slot in sketch
3. Dimension slot
4. Use extrusion command.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
