I was able to get your code to run but it wasn't what I expected. I will describe it better here.
When we run the rule or macro we want
1. All holes under 1 1/8" dia to marked with center marks and the hole disabled leaving only the center mark.
2. After the geometry and center marks are all that's left the file needs to exported "saved" into a network drive location as a 2004 dxf(or older) with the same name as the idw. We will use R:\email for our location of the dxf's
**side note
We also save a copy of the idw as a dwf with all dimensions on it for our vendors to check quality of the parts. We have something in place for that now but it would be great if we could tie it all together.
thanks,
Jason Mayes
