NSBowser
in reply to: ekinsb
I performed a similar test, running an iLogic rule (based on your VBA) and the center line shows up correctly... Obviously there is something amiss, but it escapes me.
Thanks for your time!
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
