NSBowser
2448 Views, 6 Replies
Automated Centerlines (API)
I'm using the following code to apply automated Centerlines to what is basically a simple drawing of a washer. The washer is created by extruding the area between two circles, so there is not a hole feature. On the drawings, the topview is looking at the flat sides of the washer (OD, and ID) and the section is looking at a midplane cut (Thickness).
        protected void applyAutomatedCenterlines()
            AutomatedCenterlineSettings settings = DrawingDocument.DrawingSettings.AutomatedCenterlineSettings;
            settings.ApplyToCircularPatterns = true;
            settings.ApplyToCylinders = true;
            settings.ApplyToHoles = true;
            settings.ProjectionNormalAxis = true;
            settings.ProjectionParallelAxis = true;
            _topView.SetAutomatedCenterlineSettings(settings);
            _sectionView.SetAutomatedCenterlineSettings(settings);
The result is that the centermark on the top of the washer is created, but the centerline on the section view is not.
If I select the section view afterwards and apply automated centerlines the settings I used above persit, and when applied, achieve the desired result.
I have confirmed that the _sectionView object is populated correctly.
Any thoughts why the automated version of this is not working using the same settings?
Here is a picture of the items I'm working with (desired center lines shown)
Thanks for any help!
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
