Hi Jason,
Please find a sample iLogic code in the following.
Sub Main()
	Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    oSheet = oDrawDoc.Sheets.Item(1)
    Dim obj As DrawingCurveSegment
    obj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select circle to create punch")
    obj.Visible = False
    Dim oCircleCurve As DrawingCurve
    For Each oCurve As DrawingCurve In oSheet.DrawingViews.Item(1).DrawingCurves
        If oCurve.CurveType = CurveTypeEnum.kCircleCurve Then
            For Each oSegment As DrawingCurveSegment In oCurve.Segments
                If oSegment.Equals(obj) = True Then
                    oCircleCurve = oCurve
                    oSegment.Visible = False
                    Exit For
                    Exit For
                End If
            Next
        End If
    Next
    Dim oIntent As GeometryIntent
    oIntent = oSheet.CreateGeometryIntent(oCircleCurve)
    Dim oCenter As Inventor.Centermark
    oCenter = oSheet.Centermarks.Add(oIntent)
    DXF_Export()
    obj.Visible = True
    oCenter.Delete()
End Sub
Private Sub DXF_Export()
    ' Get the DXF translator Add-In.
    Dim DXFAddIn As TranslatorAddIn
    DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        Dim strIniFile As String
        strIniFile = "C:\tempDXFOut.ini"
        ' Create the name-value that specifies the ini file to use.
        oOptions.Value("Export_Acad_IniFile") = strIniFile
    End If
    'Set the destination file name
    oDataMedium.FileName = ThisDoc.PathAndFileName(False) & ".dxf"
    'Publish document.
    Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
On running the code, it asks for a circle to select. After successful selection, a center mark is created on that circle and export to dxf at same location and same file name.
This iLogic code can be extended for multiple selection. It is also can be extended automatic selection of circles which is having lesser radius(for example, 0.5 in radius).
Please feel free to contact if there is any doubt.
If solves your problem, click on "Accept as solution" or give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
