MechMachineMan
1) Why aren't your templates just pulling from the model file that's placed in them?
2) Yes. Depending what files and your naming structure of them, it would just be something simple like:
Sub Main()
Dim oDocA As Document oDocA = ThisApplication.Document.Open("C:\T.idw") Dim oDocB As Document oDocB= ThisApplication.Document.Open("C:\F.idw") oDocB.PropertySets("Design Tracking Properties")("Stock Number").Value = _ oDocA.PropertySets("Design Tracking Properties")("Stock Number").Value
oDocA.Save
oDocA.Close
oDocB.Save
oDocB.Close
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
