JasonMayes
1749 Views, 21 Replies
Inventor idw to dxf vs ACAD dxf creation
In the transition from ACAD to Inventor I stumbled into a snag from my previous predecessor. They created a lisp routine that when fired would prompt users a series of questions with the outcome of producing a dxf file with all bolt holes replaced with cross hairs for our vendors to burn only the profile and center punch the cross hair locations to be drilled by our drill department. I have attached a pdf of the pre process and post process of the ACAD routine as well as a dxf created in Inventor. Any suggestions on how to create the same type of dxf as the ACAD version? We are currently saving back into ACAD, changing to ACAD layers, and running the command from there. Not very streamlined. Any help would be greatly appreciated.
Jason Mayes
Tags (2)
