jmfowler1996
3154 Views, 15 Replies
iLogic Rule to create description based on dimensions, bounding box, stock number
This is my way of giving back to the forum.
Thanks for all the help!
I made an iLogic rule to automatically create descriptions for parts.
Here's how it works:
1. Run the rule.
2. You are prompted to select a line of a part in a drawing view.
3. An input pox is diplayed with an overridable default description.
4. Click "OK" and you're done!
The code distinguishes between all of the content center parts in the above list,
and creates a description based on dimensions/bounding box/stock number
If you have any comments on the code, be sure to let me know :slightly_smiling_face:
I've tried to add helpful annotations, but know that I'm really not a coder.
some of this code is just stitched together from other sources.
Here ya go:
    'Code to modify a part's description iPorperty based on shape, created by Jonathan Fowler
    'Works by selecting a line segment from a part in a drawing view.
    'Document declaration
    Dim oDoc As Inventor.Document
    oDoc = ThisApplication.ActiveDocument
    'Prompt user to pick a line segment
    Dim oDrawCurveSeg As DrawingCurveSegment
    oDrawCurveSeg = ThisApplication.CommandManager.Pick _
     (Inventor.SelectionFilterEnum.
      kDrawingCurveSegmentFilter,
      "Select a Drawing Curve")
    'Get the parent DrawingCurve
    Dim oDrawCurve As DrawingCurve
    Try
        oDrawCurve = oDrawCurveSeg.Parent
    Catch ex As Exception
        Exit Sub
    End Try
    'Get the model geometry this curve represents.
    Dim oModelGeom As Object
    oModelGeom = oDrawCurve.ModelGeometry
    'Check to see if the returned object supports
    'the ContainingOccurrence property.
    Dim oOcc As ComponentOccurrence
    Try
        oOcc = oModelGeom.ContainingOccurrence
           'MessageBox.Show("Problem getting occurrence for: " & partName, "iLogic")
    End Try
    'Define model geometry
    Dim oModelGeometry = oDrawCurveSeg.Parent.ModelGeometry
    'Define component definition
    Dim oCompDef As ComponentDefinition
    oCompDef = oModelGeometry.parent.componentdefinition
    'Get part name
    partName = oCompDef.Document.DisplayName
    'Get the drawing view
    Dim oDrwView As DrawingView
    oDrwView = oDrawCurve.Parent
    'Define oPart As String
    oPart = oCompDef.Document.DisplayName & ".ipt"
    'Declare AutoType, the part shape type to be calculated.
    Dim AutoType As String
    'Define Units of Measure
    Dim uom as UnitsOfMeasure = oDoc.UnitsOfMeasure
    'Declare the range box.
    Dim oRB As Box
    Try
        'Get the range box, aligned to part UCS, excluding work geometry.
        For Each sb In oCompDef.SurfaceBodies
            If oRB Is Nothing Then
                oRB = sb.RangeBox.Copy
            Else
                oRB.Extend(sb.RangeBox.MinPoint)
                oRB.Extend(sb.RangeBox.MaxPoint)
            End If
        Next
        MessageBox.Show("Error finding extensions for part: " & partName, "iLogic")
    End Try
    Dim minp As point = oRB.minPoint
    Dim maxp As point = oRB.maxPoint
    Dim AutoName As String
    AutoName = "-"
        InventorVb.DocumentUpdate()
        Try
        oCheckFile = iProperties.Value(oPart, "Project", "Part Number")
        Catch
        MessageBox.Show("Error finding file for part: " & partName, "iLogic")
        Exit Sub
        End Try
        'Get part dimensions
        dp=0
        X = Round(uom.ConvertUnits ((maxP.X - minP.X), "cm", uom.LengthUnits), dp)
        Y = Round(uom.ConvertUnits ((maxP.Y - minP.Y), "cm", uom.LengthUnits), dp)
        Z = Round(uom.ConvertUnits ((maxP.Z - minP.Z), "cm", uom.LengthUnits), dp)
                'MessageBox.Show("Extents: " & X & " : " & Y & " : "  & Z, "iLogic")
        'Sort dimensions largest to smallest
        Thickness = MinOfMany(X, Y, Z)
        Length = MaxOfMany(X, Y, Z)
        Width = X
        If Thickness = X Or Length = X Then
            Width = Y
            If Thickness = Y Or Length = Y Then
            Width = Z
            End If
        End If
        'Get stock number properties (which are sometimes different to actual dimensions)
        Dim stockprops() As String
        Try
            stockprops = Split(iProperties.Value(oPart, "Project", "Stock Number"), "x")
        Catch
        End Try
        Try
        'Use part parameter named "Type", if it exists.
        'This can be used as an override for a part which is being wrongly assessed.
        AutoType = Parameter(oPart, "Type")
            'Test for parameters
            Try
            parametro = Parameter(oPart, "G_NG")
            G_NG = 1
            Catch
            G_NG = 0
            End Try
            Try
            parametro = Parameter(oPart, "G_T")
            G_T = 1
            Catch
            G_T = 0
            End Try
            Try
            parametro = Parameter(oPart, "G_W")
            G_W = 1
            Catch
            G_W = 0
            End Try
            Try
            parametro = Parameter(oPart, "G_ER")
            G_ER = 1
            Catch
            G_ER = 0
            End Try
            Try
            parametro = Parameter(oPart, "G_T1")
            G_T1 = 1
            Catch
            G_T1 = 0
            End Try
            'Compare to expected parameters
            If G_NG = 1 Then
            AutoType = "PFC"
            ElseIf G_T1 = 0 And G_W = 1 And G_ER = 0 And G_T = 1 Then
            AutoType = "RHS"
            ElseIf G_T = 1 And G_W = 0 Then
            AutoType = "CHS"
            ElseIf G_T = 0 And G_W = 0 Then
            AutoType = "RD BAR"
            ElseIf G_T1 = 1 And G_NG = 0 Then
            AutoType = "UC"
            ElseIf G_ER = 1 Then
            AutoType = "RSA"
            ElseIf G_W = 1 And G_T = 0 Then
            AutoType = "F BAR"
            Else
            AutoType = ""
            End If
        End Try
        'Set Shape Type
        If AutoType = "" Then
        'Prompt for manual input - in format "PFC", "F BAR", "RD BAR", "UC", etc.
        oType = InputBox("Treat as:", "Part Type", AutoType)
        Else
        'Use automatically calculated type
        oType = AutoType
        End If
        'Create a default description
        Select Case UCase(oType)
        Case "PLATE"
        AutoName = "PLT " & Thickness & " THK " & Length & " x " & Width
        Case "F BAR"
        AutoName = "F/BAR " & Width & " x " & Thickness
        Case "CHS"
        Try
        AutoName = "CHS " & Parameter(oPart, "G_H") & " OD x " & Parameter(oPart, "G_T") & " WT"
        Catch
        MessageBox.Show("Error getting parameters", "iLogic")
        AutoName = ""
        End Try
        Case "SHS", "RHS"
        Try
        'Distinguish between square and rectangular section
        If Parameter(oPart, "G_W") = Parameter(oPart, "G_H") Then
        AutoName = "SHS " & Parameter(oPart, "G_H") & " x " & Parameter(oPart, "G_W") & " x " & Parameter(oPart, "G_T")
        Else
        AutoName = "RHS " & Parameter(oPart, "G_H") & " x " & Parameter(oPart, "G_W") & " x " & Parameter(oPart, "G_T")
        End If
        Catch
        AutoName = ""
        End Try
        Case "RD BAR"
        Try
        AutoName = "RD BAR DIA. " & Parameter(oPart, "G_H")
        Catch
        AutoName = ""
        End Try
        Case "RSA"
        Try
        AutoName = "RSA " & Parameter(oPart, "G_H") & " x " & Parameter(oPart, "G_W") & " x " & Parameter(oPart, "G_T")
        Catch
        AutoName = ""
        End Try
        Case "PFC"
        Try
        AutoName = "PFC " & stockprops(0) & " x " & stockprops(1) & " x " & stockprops(2)
        Catch
        AutoName = ""
        End Try
        Case "UC", "UB"
        Try
        'Distinguish between collumn and beam
        If Val(stockprops(0)) <= Val(stockprops(1)) Then
        AutoName = "UC " & stockprops(0) & " x " & stockprops(1) & " x " & stockprops(2)
        Else
        AutoName = "UB " & stockprops(0) & " x " & stockprops(1) & " x " & stockprops(2)
        End If
        Catch
        AutoName = ""
        End Try
        Case Else
        AutoName = ""
        End Select
        'Show input box with default description
        oNewDescription = InputBox("Description for '" & partName & "':", "Description Editor", AutoName)
        If oNewDescription = "" Then
        'Cancel if no description is entered.
        MessageBox.Show("Description change cancelled.", "iLogic")
        Else
        'Change part description
        iProperties.Value(oPart, "Project", "Description") = oNewDescription
        'Restart to choose next part
        iLogicVb.RunRule("Dimensions - Individual")
        End If
