kennyj
Hi @Anonymous!
In your new custom template, delete all the other title block options.  Then as you change sheet sizes, your custom one is the only option and only choice.  Currently, to fix existing drawings, just delete the title block from the affected sheet(s) and double click to select your custom one to replace it.
If you cannot delete the default title blocks, it usually means you have associated your custom with it (copy).  You will need to remove the association.
Hope this helps,
Kenny
