- Mute
- Permalink
- Report
@GeorgK: DockableWindows Object
@nmunro: I've been working on an add-in that contains a DockableWindow with a child UserForm that displays textboxes for "Live" iProperties inside Inventor 2017; are you saying it doesn't work inside Inventor 2018** then or simply that it doesn't behave "normally" once undocked? I'm asking because I've also been investigating using a UserControl with little success.
I know @Boorda has a working example with a UserControl here; I wonder if he has had a chance to test it inside the new release yet?
**during what little I have used 2018 so far, I noticed a small bug with the way the built-in DockableWindows behave when you snap/(stack?) them to/on the edge of a monitor, but have yet to properly document/log it; when I've finished my current tranche of project work I'll stick a Screencast together showing the issue.
Alex Fielder
Inventor Expert
https://github.com/alexfielder/
LinkedIn - Github Inventor Extension Server - Bonkers polygon iLogic thing
Top ten iLogic Tips - API Shortcut In Google Chrome - Assembly Extrusion Example
