Owner2229
in reply to: Owner2229
Also tested on the below, with the same result.
Inventor 2017 64-bit SP1, Build 196, Date Wed 07/13/2016
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
