04-05-2017
05:01 AM
- Mute
- Permalink
- Report
04-05-2017
05:01 AM
And now for my next question:
Because there is no exposed method for creating and therefore(?) accessing the WrapToSurface object, I seem to be unable to identify the referenced SketchPoint using the following code:
ObjectCollection objCollection = partDoc.AttributeManager.FindObjects("RadialHole", "HolePositionX");
ObjectCollection sketchPointsColl = RadialHoles.m_InventorApp.TransientObjects.CreateObjectCollection();
for (int i = 1; i < objCollection.Count + 1; i++)
if (objCollection[i] is SketchPoint)
//may need to cast this to a temporary object to prevent errors?
SketchPoint tmpSketchPoint = objCollection[i];
sketchPointsColl.Add(tmpSketchPoint);
partDoc.SelectSet.SelectMultiple(sketchPointsColl);
partDoc.SelectSet.Select(selectedFace);
ControlDefinition Sketch3DWrapToSurface = RadialHoles.m_InventorApp.CommandManager.ControlDefinitions["Sketch3DProjectCmd"];
//.Execute2(true) means we can continue afterwards!
Sketch3DWrapToSurface.Execute2(true);
if(new3DSketch.SketchPoints3D.Count > 0)
foreach (SketchPoint3D item in new3DSketch.SketchPoints3D)
/*next line returns null; the item.reference property is true but item.ReferencedEntity = null
SketchPoint referencedSkPoint = (from SketchPoint skp in sketchPointsColl
where item.ReferencedEntity == skp
select skp).FirstOrDefault();
Looks like I will need to create transient geometry points in the same way I did before, store their X,Y,Z coordinates and then compare those locations to each wrapped SketchPoint3D to identify the correct location and it's resultant hole information (size, name etc.).
Unless there's a method for querying the original SketchPoint objects to see what they are referenced by?
Cheers,
Alex.
Alex Fielder
Inventor Expert
https://github.com/alexfielder/
LinkedIn - Github Inventor Extension Server - Bonkers polygon iLogic thing
Top ten iLogic Tips - API Shortcut In Google Chrome - Assembly Extrusion Example
Alex Fielder
Inventor Expert
