wayne.brill
in reply to: AlexFielder
Hi Alex,
I do not have anything to suggest after looking at your code and I believe there is not any API method that directly wraps a curve to a surface like the UI can do.
Could you explain more about what part of the code you are trying to simplify? Also a description of the workflow that the user would take and what the code is doing may help.  I see a WorkPoint and a WorkAxis being created but I am not seeing where a curve is being created on a surface.
This post seems related but not sure if it will help:
http://modthemachine.typepad.com/my_weblog/2016/06/projecting-points-onto-a-solid.html
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
