- Mute
- Permalink
- Report
Is there a way to change iProperties in several open .idw files at the same time?
I have a main assembly and in the title block I specify through custom iProperties Job number, customer name, address and etc.
The problem is that I also have a lot of standard library idw. drawings I include and need to enter job number, customer name and etc. in each single one of them, which takes a lot of time.
So I was wondering if there is a way to do this change once or somehow speed this process up? I would use excel to link it, but then I would have to specify path every time to a new excel file. Could probably use Vault, but I don't want to alter standard drawings with every job.
Maybe thru iLogic external rule somehow?
