kennyj
416 Views, 2 Replies
Part Rule to Run while Edit in Place at Assembly Level
With the help of this forum, I have the following rule which works great a the part level, external rule.
My users though, have tried to run the rule while in an assembly, editing the part in place.  The rule as written adds the parameters at the assembly level, not to the activated part file.
Can one of you gurus show me how to have my rule apply the parameters to the part that is being edited not the assembly that the part was accessed from?
Thank you in advance,
Kenny
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 6532 StartFragment: 314 EndFragment: 6500 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Sub Main()
Dim oDoc As PartDocument
oDoc=ThisApplication.ActiveDocument
Dim oUserParam1 As UserParameter
oUserParam1=oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("CMF_COORD_X", 0, UnitsTypeEnum.kFootLengthUnits)
Dim oUserParam2 As UserParameter
oUserParam=oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("CMF_COORD_Y", 0, UnitsTypeEnum.kFootLengthUnits)
Dim oUserParam3 As UserParameter
oUserParam3=oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("CMF_COORD_Z", 0, UnitsTypeEnum.kFootLengthUnits)
End Sub
