- Mute
- Permalink
- Report
Auto balloon using iLogic
hey guys!
Trying to find a way to auto-balloon all part on drawing created using iLogic.
Currently my assembly is driven by iLogic, iLogic also generates the idw but I can't find a way to balloon the part other than manually.
Is there a code snippet for auto balloon?
Thanks!
- Mute
- Permalink
- Report
to create a balloon with VBA, this is the code from the Inventor help:
Public Sub CreateBalloon()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet
Set oActiveSheet = oDrawDoc.ActiveSheet
' Set a reference to the drawing curve segment.
' This assumes that a drwaing curve is selected.
Dim oDrawingCurveSegment As DrawingCurveSegment
Set oDrawingCurveSegment = oDrawDoc.SelectSet.Item(1)
' Set a reference to the drawing curve.
Dim oDrawingCurve As DrawingCurve
Set oDrawingCurve = oDrawingCurveSegment.Parent
' Get the mid point of the selected curve
' assuming that the selection curve is linear
Dim oMidPoint As Point2d
Set oMidPoint = oDrawingCurve.MidPoint
' Set a reference to the TransientGeometry object.
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oLeaderPoints As ObjectCollection
Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
' Create a couple of leader points.
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 10))
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 5))
' Add the GeometryIntent to the leader points collection.
' This is the geometry that the balloon will attach to.
Dim oGeometryIntent As GeometryIntent
Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
Call oLeaderPoints.Add(oGeometryIntent)
' Set a reference to the parent drawing view of the selected curve
Dim oDrawingView As DrawingView
Set oDrawingView = oDrawingCurve.Parent
' Set a reference to the referenced model document
Dim oModelDoc As Document
Set oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
' Check if a partslist or a balloon has already been created for this model
Dim IsDrawingBOMDefined As Boolean
IsDrawingBOMDefined = oDrawDoc.DrawingBOMs.IsDrawingBOMDefined(oModelDoc.FullFileName)
Dim oBalloon As Balloon
If IsDrawingBOMDefined Then
' Just create the balloon with the leader points
' All other arguments can be ignored
Set oBalloon = oDrawDoc.ActiveSheet.Balloons.Add(oLeaderPoints)
Else
' First check if the 'structured' BOM view has been enabled in the model
' Set a reference to the model's BOM object
Dim oBOM As BOM
Set oBOM = oModelDoc.ComponentDefinition.BOM
If oBOM.StructuredViewEnabled Then
' Level needs to be specified
' Numbering options have already been defined
' Get the Level ('All levels' or 'First level only')
' from the model BOM view - must use the same here
Dim Level As PartsListLevelEnum
If oBOM.StructuredViewFirstLevelOnly Then
Level = kStructured
Else
Level = kStructuredAllLevels
End If
' Create the balloon by specifying just the level
Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , Level)
Else
' Level and numbering options must be specified
' The corresponding model BOM view will automatically be enabled
Dim oNumberingScheme As NameValueMap
Set oNumberingScheme = ThisApplication.TransientObjects.CreateNameValueMap
' Add the option for a comma delimiter
oNumberingScheme.Add "Delimiter", ","
' Create the balloon by specifying the level and numbering scheme
Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , kStructuredAllLevels, oNumberingScheme)
End If
End If
End Sub
Kudo's are also appreciated
Succes on your project, and have a nice day
Herm Jan
- Mute
- Permalink
- Report
Yeah I based my code for automated drawing almost entirely on this thread. But there's no mention of balloon in the thread. At least didn't see any.
Thanks for the code. I'll have a look at it pretty soon. You mentioned you got it from inventor help? I haven't seen anything this detailed in inventor help, where did you find it?
- Mute
- Permalink
- Report
it comes from the help in Inventor:
Herm Jan
- Mute
- Permalink
- Report
I looked at the code from the help. It will add a balloon to the midpoint of the line that is selected.
My guess is that with a For loop I could go and add a balloon to each of the part. But how would I tell it to go and look for line 1 of part1 and then line 1 of part2?
- Mute
- Permalink
- Report
Have you achieved your goal?
Don't you know how to automate check for ballooning all ItemRefs in PartList (manually you just check if there is a "balloon sign" in each cell of first column when in PartList editing mode)?
Please vote for Inventor-Idea Text Search within Option Names
- Mute
- Permalink
- Report
Got it - DrawingBOMRow.Ballooned Property.
Sorry for have disturbed.
- Mute
- Permalink
- Report
Herm Jan
We upgraded to Inventor Pro 2019, I have tried to run this code through the VBA EDITOR and will not run.
Run time error '5':
Invalid procedure call or argument.
The debug has gone to this line
Any suggestions
- Mute
- Permalink
- Report
this line will only work if you first have selected a line.
so select a line, (that wil than be in the "SelectSet") than run the code
if nothing is in the selectset, you will get an error.
Herm Jan
