- Mute
- Permalink
- Report
This is still an issue where I work. The problem here is that we have a network drive where all materials are saved along with images. Project file maps to these locations, but Vault doesn't like the network drive for this. The only fix I have seen so far is to open the offending part, select TOOLS>LINKS, there you will see the image file causing you the grief, you can break the link here. Autodesk: how do we customize material images on a multi-user environment where materials and images are stored on a network drive using a Vault project file? I have seen one option: store all materials/appearances (basically the design data folder) on Vault. Folks will have to manually download the latest changes, but no offending links.... Thoughts on this Autodesk?
