asiteur
I see your problem. I never use 'place ilogic' component, but it seems to be a valid workflow issue.
I would consider one of the following:
1) Have a 'Master'assembly in which you place each ilogic component first, such that the partname is unique. And then call it in the actual assembly where you need it.
2) Making 'copy designs' of the parts you want to place and then place them in the reqular way.
Both options would have you create some sort of library.
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
