232 Views, 2 Replies
Same name issue when calling the iLogic components to different subassemblies
I have an assembly which is opened in a specific project file. The assembly also has subassemblies which are located in separate files. But they are in the same project file for sure. When I call (as Place iLogic Component) the iLogic component in a specific subassembly, the assembly parts of that iLogic component renamed as ":1,:2" etc. as usual. However when I place the reconfigured iLogic component to a different subassembly it is also renamed as ":1,:2" etc. This situation makes problems when I want to use 'Pack and Go' command since the some part names are the same.
I am struggling with this issue for a long time so if anyone could help me I will definetly appreciate. Thanks.
