chandra.shekar.g
in reply to: GeorgK
Hi George,
Please find the sample code to change the hole without sketch
Public Sub ModifY_Hole()
        Dim m_inventorApp As Inventor.Application = Nothing
        ' Try to get an active instance of Inventor
        Try
            m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
        ' Create a transaction.
        Dim oTransMgr As TransactionManager
        oTransMgr = m_inventorApp.TransactionManager
        Dim oTrans As Transaction
        oTrans = oTransMgr.StartTransaction(m_inventorApp.ActiveDocument, "Replace hole")
        Dim oSketch As PlanarSketch = Nothing
        Dim oDoc As PartDocument
        oDoc = m_inventorApp.ActiveDocument
        ' Set a reference to the component definition.
        Dim oCompDef As PartComponentDefinition
        oCompDef = oDoc.ComponentDefinition
        Dim oCollection As ObjectCollection
        oCollection = m_inventorApp.TransientObjects.CreateObjectCollection
        Dim ohole As HoleFeature
        ohole = m_inventorApp.CommandManager.Pick(SelectionFilterEnum.kPartFeatureFilter, "Select hole feature")
        ohole.SetCBore("10 mm", "2.5 mm")
        oTrans.End()
    End Sub
Please feel free to contact if there is any doubt.
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
