03-06-2017
11:29 PM
- Mute
- Permalink
- Report
03-06-2017
11:29 PM
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button65.Click
Dim m_inventorApp As Inventor.Application = Nothing
' Try to get an active instance of Inventor
Try
m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
Catch ex As Exception
MsgBox(ex.Message)
End Try
' Create a transaction.
Dim oTransMgr As TransactionManager
oTransMgr = m_inventorApp.TransactionManager
Dim oTrans As Transaction
oTrans = oTransMgr.StartTransaction(m_inventorApp.ActiveDocument, "Replace hole")
Dim oSketch As PlanarSketch = Nothing
Dim oDoc As PartDocument
oDoc = m_inventorApp.ActiveDocument
' Set a reference to the component definition.
Dim oCompDef As PartComponentDefinition
oCompDef = oDoc.ComponentDefinition
Dim oHoles As HoleFeatures
oHoles = oDoc.ComponentDefinition.Features.HoleFeatures
Dim oHole As HoleFeature
For Each oHole In oHoles
oDoc.SelectSet.Clear()
oDoc.SelectSet.Select(oHole)
Dim oHoleCenter As Point
Dim oSketchPoint As SketchPoint
Dim oCollection As ObjectCollection
oCollection = m_inventorApp.TransientObjects.CreateObjectCollection
If TypeOf oHole.HoleCenterPoints.Item(1) Is SketchPoint Then
' Get the sketch point.
oSketchPoint = oHole.HoleCenterPoints.Item(1)
' Get the position of the sketch point in model space.
oSketch = oSketchPoint.Parent
oHoleCenter = oSketch.SketchToModelSpace(oSketchPoint.Geometry)
'Dim oSketchpoint As SketchPoint
For Each oSketchPoint In oHole.Sketch.SketchPoints
If oSketchPoint.HoleCenter Then
Call oCollection.Add(oSketchPoint)
End If
Next
'Löschen
oHole.Delete(True)
Call oCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent(oCollection, "10 mm", PartFeatureExtentDirectionEnum.kPositiveExtentDirection)
oDoc.Update()
Else
oHoleCenter = oHole.HoleCenterPoints.Item(1)
MsgBox(oHoleCenter.X & "; " & oHoleCenter.Y & "; " & oHoleCenter.Z)
' How to replace the hole without sketch?
End If
Next
oTrans.End()
End SubHow could I replace the holes without sketch?
