HermJan.Otterman
in reply to: spencer
hello Spencer,
are the parts that you create custom parts are standard parts and will they be used many times?
If you create standard parts, with you own parameters, location will be somewhere in a library.
the name of the part should be automaticaly created in the content center part, (combination of columns and user input)
If you do it that way, you don't need to check if the file exists, Inventor will do that for you.
I used this:
Dim oFamily As Inventor.ContentFamily = Nothing
For Each oFamily In oContentNode.Families
If oFamily.DisplayName = FamilyName Then
Exit For
End If
Next
Dim errorMessage As Inventor.MemberManagerErrorsEnum = Nothing
Dim strContentPartFileName As String = Nothing
Dim strErrorMessage As String = Nothing
strContentPartFileName = oFamily.CreateMember(RowNumber, errorMessage, strErrorMessage, , False, , CustomInput)
In my assembly there are already (dummy) parts that can be replaced
'Replace the existing occurrence with the newly created one.
oOcc.Replace(strContentPartFileName, False)
the CustomInput is the nameValueMap.
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
