- Mute
- Permalink
- Report
Quick idea to run ilogic rule on view representation change
Anyone got a quick brilliant idea to run a rule every time a view representation is changed??
(it's a very complicated assembly with lots of sub-ass'y, iassembly and ilogic part talking to each other and i want to spare the user the need to open different view rep and run the rule for each of them.)
Thanx in advance!
- Mute
- Permalink
- Report
HI yvandelafontaine,
The one way I can think of, to achieve this, is by using the RepresentationEvents.OnActivateDesignView Event.
Below is a sample piece of code that may help you get started.
Copy the below code into a code module.
Dim oRepCls As cRepEvents ' Create a new cRepEvents object
Sub StartEvents()
Set oRepCls = New cRepEvents
End Sub
Sub StopEvents()
Set oRepCls = Nothing
End Sub
Create a new class module called cRepEvents and copy below code into it, since VB only supports events within a class module
Private WithEvents RepEvents As RepresentationEvents
Private Ilogicaddin As Object
Private Sub Class_Initialize()
Set RepEvents = ThisApplication.RepresentationEvents
Set Ilogicaddin = ThisApplication.ApplicationAddIns.ItemById("{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}").Automation ' Get ilogic addin to run the rule
End Sub
Private Sub Class_Terminate()
Set RepEvents = Nothing
End Sub
Private Sub RepEvents_OnActivateDesignView(ByVal DocumentObject As Document, ByVal Representation As DesignViewRepresentation, ByVal BeforeOrAfter As EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum)
Ilogicaddin.RunRule DocumentObject, "Rule0" ' The rule name that needs to be executed
End Sub
Let me know if this helps.
Sajith
Sajith Subramanian
Autodesk Developer Network
- Mute
- Permalink
- Report
I really am intrigued by this, i have learned ilogic and this is the first time that i am seeing such code that is run in this matter.
Could you please help me in a similar action?
I am trying to run a rule after Visibility Change in the model. Yet there is nothing on the web that will help me learn and understand how to do this. I believe after stumbling on this, that you may be able to help me.
Looking forward to your comments.
See My LinkedIn Profile
- Mute
- Permalink
- Report
Hi @DeerSpotter,
By Visibility change in the model, I assume you mean the below?
So you are looking to execute a ilogic rule whenever a user changes the above options?
Sajith
Sajith Subramanian
- Mute
- Permalink
- Report
