rhasell
in reply to: martinhoos
Hi
I quickly had a look in the help files and made this up for you.
Have a look and see if this fixes your problem.
I changed it to sort the structured list
' Set a reference to the assembly document.
' This assumes an assembly document is active.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
' Set a reference to the BOM
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
	oBOM.StructuredViewFirstLevelOnly = False
	oBOM.StructuredViewEnabled = True
	Dim oStructuredBOMView As BOMView
    oStructuredBOMView = oBOM.BOMViews.Item("Structured")
Call oStructuredBOMView.Sort("BOM Structure",True ,"TYPE",True ,"Stock Number",True)
Call oStructuredBOMView.Renumber(1, 1)
MessageBox.Show("Done", "Sort BOM")
Reg
2025.2
