in reply to: Owner2229
I tried that out, and it gave me an "invalid procedure call or argument." I think it has to do with the fact that it's an iPart.
I created a function to call in my main sub that ended up working:
Function FindDrain(o As ComponentOccurrence)
FindDrain = False
Dim iPartRow As iPartTableRow
Set iPartRow = o.Definition.iPartMember.Row
If iPartRow.Item(17).Value = "Compute" Then
FindDrain = True
End If
End Function
By going into Definition.iPartMember.Row, I gain access to the current occurrence's row in the iPart table. Item(17) is the column associated with Drain Port E2. In the iPart table, the feature is either set to "Compute" or "Suppress."
