02-15-2017
12:16 PM
- Mute
- Permalink
- Report
02-15-2017
12:16 PM
It is in VBA, so you can use the Macro environment.
Although + F11.
Right click and insert a new module under the Application Project.
Paste the code from the last post in that thread.
Save.
Hit the macro button under Tools Ribbon.
Run the macro.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Although + F11.
Save.
Run the macro.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
