377 Views, 3 Replies
Graphical line missing in drawing
Hi all,
I have an assembly with a bracket fixed into a concrete slab (see below)
The problem is I would like to see the intersection edge in my drawing. See below again:
Is there any setting in Inventor that I should check?
HermJan.Otterman
Hello Hashang,
is this in a drawing?
in 2017, edit the view, and select, display options tab, Interference edgesCapture.PNG
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
CADguru21
This situation occurs whenever a part is sticking through another without a visible mating face.
Simply double-click on the view and select "Interference Edges" in the "Display Options" tab.
in reply to: HermJan.Otterman
Thanks for the reply. That was it. But I was wondering if I can have this feature enabled by default for all of my views in drawings (something like Application Setting)
