BrandonBG
885 Views, 8 Replies
Model parameters in leader FormattedText attached to component via API
Anyone found a workaround for this yet?
Via the API, I'm unable to recreate Leader Text (attached to component), Edit Leader Text, insert Model Property from part. My understanding is that the XML structure for FormattedText holds for an assembly, but not a part.
See these threads:
https://forums.autodesk.com/t5/inventor-customization/inventor-2008-leadernote-formattedtext/td-p/19...
https://forums.autodesk.com/t5/inventor-customization/xml-text-for-part-parameter-in-a-leader-note/t...
http://adndevblog.typepad.com/manufacturing/2012/07/create-leader-note-with-the-value-of-user-or-mod...
Brandon
