in reply to: Owner2229
What i basically want to happen is the following;
  1. Manually place folded parts on drawing (lets say on sheet 2)
  2. Select all the folded parts views on sheet 2
  3. Run the rule to add the flat pattern of the parts on the same sheet as the folded views and delete the folded views
What is happening with the code i mentioned above;
  3. Run the rule
  4. Flat pattern of the parts are created and placed on sheet 1 and the folded views are deleted (not what i want)
So, is there a way to direct the new view to the sheet and position of the original folded view?
Could you maybe give a direction in the following sentence?
oSheet.DrawingViews.AddBaseView(oModel, oPoint, oScale, oOri, oViewStyle, , , oOptions)
 Or is there an other way to do it?
Greetings
