02-01-2017
03:55 AM
- Mute
- Permalink
- Report
02-01-2017
03:55 AM
Do you want to select the views that should be processed for each sheet?
If so, you have to move the selection pick to the "For each sheet" loop and prompt user for input.
I don't see how you could pre-select views from multiple sheets... do you want to only select the views from first sheet and process all views from all the other sheets?
Or is there a condition for the views that we could code in?
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Mike
