Rob67ert
Hallo Jesse,
Maybe you can use this:
SyntaxEditor Code Snippet
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDrawingDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oView1 as DrawingView
Dim oView2 as DrawingView
Dim oView3 as DrawingView
Dim oView4 as DrawingView
ViewScale = 1
'Ask to create drawing?
dwgQuery=MsgBox("Would you like to Create a drawing for this MODEL?", vbYesNo,"Drawing Selection")
If dwgQuery = vbYes Then
    oPartDoc = ThisDoc.Document
    'Check to see if part is a sheetmetal part
    If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
        'do nothing
    Else
        'ensure this part has a flat pattern
        Dim oSMDef As SheetMetalComponentDefinition
        oSMDef = oPartDoc.ComponentDefinition
        If oSMDef.FlatPattern Is Nothing Then
        'create flat pattern
        oSMDef.Unfold
        oSMDef.FlatPattern.ExitEdit
        oSMDef.FlatPattern.FlipBaseFace
        Else
        'do nothing
        End If
    End If
    'Define IDW Template File Location
    oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Temp\my template.idw", True)
   oSheet = oDrawingDoc.Sheets.Item(1)
      ' Create a new NameValueMap object
  Dim oBaseViewOptions As NameValueMap
  oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
 'True = folded view
 'False = flat pattern view
  oBaseViewOptions.Add("SheetMetalFoldedModel", False)
'Define 2d view bottom left corner points for four views
'oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(9, 10) ' front view
'oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(9, 14) ' top view
'oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(18, 10)' right view
oPoint4 = ThisApplication.TransientGeometry.CreatePoint2d(20, 18)' flat pattern
'oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, ViewScale,kFrontViewOrientation, kHiddenLineDrawingViewStyle, "My View")
'oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2, kHiddenLineDrawingViewStyle, ViewScale)
'oView3 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3, kHiddenLineDrawingViewStyle, ViewScale)
oView4 = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint4, ViewScale,kDefaultViewOrientation, kHiddenLineDrawingViewStyle,,, oBaseViewOptions)
End If
'kDefaultViewOrientation = 10753 (Default folded Or flat pattern view)
'kFlatPivotRightViewOrientation = 10767
'kFlatPivotLeftViewOrientation = 10768
'kFlatPivot180ViewOrientation = 10769
'kFlatBacksideViewOrientation = 10770
'kFlatBacksidePivotRightViewOrientation = 10771
'kFlatBacksidePivotLeftViewOrientation = 10772
'kFlatBacksidePivot180ViewOrientation = 10773
I already changed it a bit, it will now only make a view from the flat pattern from the open sheetmetal part.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
