try this:
 Sub Main()
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition = Nothing
oAsmCompDef = oAsmDoc.ComponentDefinition
Dim oCustomParamGroup As CustomParameterGroup = Nothing
Try
oCustomParamGroup = oAsmCompDef.Parameters.CustomParameterGroups.Add("Category name", "Category name")
Catch ex As Exception
'it probably already exists
oCustomParamGroup = oAsmCompDef.Parameters.CustomParameterGroups("Category name")
End Try
'enter existing parameter name, and copy the line for more parameters
Dim oExistingParam As Inventor.Parameter = GetExistingParam(oAsmDoc, "Length")
'add parameter
oCustomParamGroup.Add(oExistingParam)
Dim oExistingParam1 As Inventor.Parameter = GetExistingParam(oAsmDoc, "Width")
'add parameter
oCustomParamGroup.Add(oExistingParam1)
 End Sub
Private Function GetExistingParam(ByVal oAssydoc As Inventor.AssemblyDocument, oParamName As String) As Inventor.Parameter
Dim oParam As Inventor.Parameter = Nothing
For Each oParam In oAssydoc.ComponentDefinition.Parameters
If oParam.Name = oParamName Then
Return oParam
End If
Next
Return Nothing
End Function
put it all in one iLogic rule
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
