01-23-2017
09:30 AM
- Mute
- Permalink
- Report
01-23-2017
09:30 AM
Hello Thomas,
Look in the API help for: Custom Parameter Groups, and you will find this code:
it might help you. (This is API only!)
Public Sub CreateParametersAndGroup()
' Create a new Part document.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
' Set a reference to the compdef.
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
' Create a model parameter
Dim oModelParam As ModelParameter
Set oModelParam = oCompDef.Parameters.ModelParameters.AddByValue(2, kCentimeterLengthUnits)
' Create a reference parameter
Dim oReferenceParam As ReferenceParameter
Set oReferenceParam = oCompDef.Parameters.ReferenceParameters.AddByValue(4, kCentimeterLengthUnits)
' Create a user parameter
Dim oUserParam As UserParameter
Set oUserParam = oCompDef.Parameters.UserParameters.AddByValue("length", 6, kCentimeterLengthUnits)
' Create a new custom parameter group
Dim oCustomParamGroup As CustomParameterGroup
Set oCustomParamGroup = oCompDef.Parameters.CustomParameterGroups.Add("Custom Group", "CustomGroup1")
' Add the created parameters to this group
' Note that adding the parameters to the custom group
' does not remove it from the original group.
Call oCustomParamGroup.Add(oModelParam)
Call oCustomParamGroup.Add(oReferenceParam)
Call oCustomParamGroup.Add(oUserParam)
End Sub
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated
Succes on your project, and have a nice day
Herm Jan
Herm Jan
