in reply to: Owner2229
Place for the opening is always on the spline. Spline - it is rather isocurve, because the surface is always on and repeats it.
The points for the holes to be selected counter. And the diameter should be selected only two - the largest and the smallest. The diameters between large and small should decrease uniformly.
For example: 1. The large diameter of 5mm, 0.7mm small
                    2. Step between holes 0.2mm
As a result, iLogic must calculate the number of holes in increments of 0.2mm in said isocurve and reduce the diameter from 5mm to 0.7mm evenly. Or choose to reduce the diameter of the said advance otdelnom box (a list of diameters). If it is not possible to place these holes display a message that is not possible to place a given number of openings of the curve on this curve.
Start holes can be set using the indent (specify manually).
Yes holes are always perpendicular to the surface.
Lines - a (very often) offset from the surface of the rib (in rinoceros - this is called isocurve)
Post Inventor:
(Failed to create the hole.Part1.ipt: Error updating An error in the calculation of the sketch. Use the "Sketch" command tochange sketch geometry or relationships.3D Sketch2: Problems when you try to perform an operation of 3D sketch)
