Owner2229
in reply to: Jef_E
Hi, it depends on if you save each new created part after it's created or create them within an assembly and save them only when user hits save manually.
If the parts are already saved, the only thing that will happen is they'll be excluded from the assembly.
I'd personally exclude the parts' creation from the transaction or wrap them in their own.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
