01-16-2017
12:54 PM
- Mute
- Permalink
- Report
01-16-2017
12:54 PM
Try this in a rule and report back to how it runs:
AddReference "Microsoft.Office.Interop.Excel" 'To use excel
Sub Main()
oExcelPath = "G:\FSH_Engineering\ENGINEERING DRAWINGS\_DRAWING TEMPLATES\_INVENTOR\_START PARTS\UTILITY\GAUGE.xlsx"
oSheetName = "Sheet1"
Dim xlApp As Microsoft.Office.Interop.Excel.Application
xlApp = GetObject("", "Excel.Application")
Dim xlwb As Microsoft.Office.Interop.Excel.WorkBook
xlwb = xlApp.Workbooks.Open(oExcelPath)
Dim xlws As Microsoft.Office.Interop.Excel.Worksheet
xlws = xlwb.Worksheets(oSheetName)
MsgBox("Cell A1 is: " & xlws.Cells(1, "A").Value)
xlwb.Close(SaveChanges:= False)
xlApp.Quit
xlApp = Nothing
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
