adam.nagy
This is how you can run things inside your own command.
Here is a VBA sample.
E.g. have a class named "MyCommand" with this code:
Option Explicit
Dim WithEvents bd As ButtonDefinition
Private Sub bd_OnExecute(ByVal Context As NameValueMap)
  Dim ie As InteractionEvents
  Set ie = ThisApplication.CommandManager.CreateInteractionEvents
  ' Set name of ActiveCommand
  ie.Name = "MyCommand"
  Call ie.Start
  ' Do something as part of the command
  Call MsgBox("ThisApplication.CommandManager.ActiveCommand = " + _
    ThisApplication.CommandManager.ActiveCommand)
  Call ie.Stop
End Sub
Private Sub Class_Initialize()
  Dim cm As CommandManager
  Set cm = ThisApplication.CommandManager
  Set bd = cm.ControlDefinitions.AddButtonDefinition( _
    "MyCommand", "MyCommand", kNonShapeEditCmdType, , "MyCommand", , , , kAlwaysDisplayText)
  ' Run it Synchronous=True
  Call bd.Execute2(True)
  ' If it was really synchronous then by the time we get
  ' here we're done and don't need the command anymore
  Call bd.Delete
End Sub
Then instantiate it from a module:
Dim mc As MyCommand
Sub RunMyCommand()
  Set mc = New MyCommand
End Sub
This way while your command is running, the ActiveCommand will be "MyCommand" and OnActivateCommand/OnTerminateCommand events should fire as well.
PS: I have a couple of largeish assemblies I just could not make Inventor think too much after an Update yet.
I'll try to find a way for that.
Cheers,
Adam Nagy
Autodesk Platform Services
