MechMachineMan
Or try something along these lines (from API samples)
Public Sub AddOccurrence()
    ' Set a reference to the assembly component definintion.
    ' This assumes an assembly document is open.
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    ' Set a reference to the transient geometry object.
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    ' Create a matrix.  A new matrix is initialized with an identity matrix.
    Dim oMatrix As Matrix
    Set oMatrix = oTG.CreateMatrix
    ' Set the rotation of the matrix for a 45 degree rotation about the Z axis.
    Call oMatrix.SetToRotation(3.14159265358979 / 4, _
                            oTG.CreateVector(0, 0, 1), oTG.CreatePoint(0, 0, 0))
    ' Set the translation portion of the matrix so the part will be positioned
    ' at (3,2,1).
    Call oMatrix.SetTranslation(oTG.CreateVector(3, 2, 1))
    ' Add the occurrence.
    Dim oOcc As ComponentOccurrence
    Set oOcc = oAsmCompDef.Occurrences.Add("C:\Temp\Part1.ipt", oMatrix)
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
