mk92
222 Views, 1 Reply
User input
we have an Part with 4 Parameter, lets call them A,B,C,D they are depending on each other in their formulas.
If A changes, the other three have to be new calculated.
I got this working, but i think in an unelegant way. I use a Parameter like A-Memory as help and i say:
If A <> A-Memory then
B = ...
C...
D..
End if
And the same for B,C,D. Is there a better way?
Now the Point where i dont know any solution except a huge ton of If else chains.
If A and B Change at the same time (which is possible in the Factory Design Suite) the other 2 are new calculated and A,B are fix.
Any ideas?
Kind regards
Owner2229
in reply to: mk92
Hi, it would be nice to see the equations for these to fully understand your request, but here's what comes on my mind:
You can create 4 rules, each starting with:
s = A 'or B or C or D
The "s = A" then serves as a trigger when the parameter "A" changes.
Below this you can write your equations, e.g.:
s = A
B = A * 2
C = B * 3
D = A + 4
Don't wrap it in "Parameter("d0"). E.g. for the parameter called "d0" it will be:
s = d0
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
