adam.nagy
Would you be able to provide a non-confidential set of files and a small sample code that would enable us to reproduce the behaviour?
Concerning ActiveCommand. I assume you are not creating a command for your program and run the code from it, so the ActiveCommand would be the DefaultCommand.
I could not find anything logged against Update2() not executing synchronously. What about using Update()? Does that have the same problem?
If this turns out to be an issue then maybe placing your code inside a command, running that synchronously, and then waiting for the OnTerminateCommand() event to run the SaveAs part might be a workaround. We'll see.
Cheers,
Adam Nagy
Autodesk Platform Services
