348 Views, 1 Reply
Inventor 2016 Hot Key entry
It, admittedly, has been around 13 months since I have sat down to do some serious design, but I do remember that I was faster at it, I came from quite a few years as an AutoCAD guy, so I love using the keyboard hot keys for different commands.  When I was working for a tool supplier I remember being able to use hot keys without hitting Enter or the space bar, is there a setting to make this happen?
Thanks in Advance!!
HermJan.Otterman
it already works this way.
with the spacebar you can repeat the last command.
go to Tools, Customize, to change the key's if you want.
what I do, in the Application options, general, is checking the three checkboxes for "Prompting interaction"
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
