12-22-2016
08:02 AM
- Mute
- Permalink
- Report
12-22-2016
08:02 AM
See my notes below.
@CCarreiras wrote:
Hi!
I'm trying to create two custom properties (Flat Pattern Extends: With and Length) in sheet metal parts within main assembly.
I tried another code, but it's only create the properties in the main assembly, not in the parts.
Now, I'm trying this code below, but it's not working yet.
Any help?
Thanks.
SyntaxEditor Code Snippet
Dim openDoc As Document openDoc = ThisApplication.activedocument Dim docFile As Document 'Is Assembly? If openDoc.DocumentType = 12291 Then For Each docFile In openDoc.AllReferencedDocuments 'Is Sheet Metal File? (assuming it has FP already) If docFile.SubType.Equals("{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then 'if yes, Assuming it has a Flat Pattern deffined Dim smComp As SheetMetalComponentDefinition smComp = docFile.ComponentDefinition If smComp.HasFlatPattern = True Then 'CREATE With and Length as user properties (NOT WORKING) Dim Prop_Length As String Dim Prop_With As String
'ThisDoc.Document is accessing the active assembly document rather than iterating through docFile with you.
'The fix: replace ThisDoc.Document in this case with docFile oCustomPropertySet = ThisDoc.Document.PropertySets.Item _ ("Inventor User Defined Properties") oCustomPropertySet.Add("Custom", Prop_Length) oCustomPropertySet.Add("Custom", Prop_With)
' oCustomPropertySet is already a fully defined object (as you have worked your way down to it with the previous call we fixed.
'The fix: just delete docFile. from this line. 'Adds Flat Pattern extends (Length and With) as a custom propertie (ready to use in a Part List Column) (NOT WORKING) docFile.oCustomPropertySet.Item("Design Tracking Properties").Item("Custom", "Length").Value = "=<Sheet Metal Length>" docFile.oCustomPropertySet.Item("Design Tracking Properties").Item("Custom", "Width").Value = "=<Sheet Metal Width>" 'THIS LINE IS TO ABLE THE Thickness PARAMETER TO GET READY TO EXPORT IN EACH SHEET METAL PART (WORKING) docFile.ComponentDefinition.Parameters("Thickness").ExposedAsProperty = True Else MessageBox.Show("No Flat Pattern Info ", "INFO!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation) End If Else MessageBox.Show("Not a SM Part", "INFO!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation) End If Next Else MessageBox.Show("This is not an Assembly", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation) End If
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
